1996 Ford Ranger Clunk or banging, Driveshaft or Tranny?
260,000 MILES • 6 CYL • 4WD • MANUAL
ERNREB1
It sounds like a banging in my Transmission, most especially when I down shift but also sometimes when I go in reverse and sometimes Even when Im starting out in 1st gear....but most notably when I have downshifted. I do not notice a change in RPMs or much vibration through the shifter. Upon closer inspection I have noticed some play in the driveshaft and the sound it makes when I manually (with my hand) work the play in the drive shaft sound like what I am hearing as I downshift. Im not sure if the play is in the Trans or the rear differential.
What would cause this play and how might I be able to fix it?
Dec 2, 2008 at 6:51 AM
JAMES W.
  • 2,394 POSTS
With the transmissiom in neutral if you can turn the rear driveshaft more than a few degrees, you probably have a differential problem. By a few degrees, I mean about "8" which very little. If the rearend is bad, you should hear a howl when going down the road at 35 to 45 MPH. Please advise.
Dec 2, 2008 at 7:40 AM
ERNREB1
I dont know how many degrees but I estimate 1 - 1 1/2 inches of play in the driveshaft when I turn it by hand. I cannot hear any howling but I have a louder exhaust system so I may be missing it. Any other at home tests you could suggest to confirm that it is a problem in the rear end?
Anything would be appreciated.
Thanks
Dec 2, 2008 at 12:12 PM
JAMES W.
  • 2,394 POSTS
The slack in the rearend, going by inches should not be more than 1/4" of play. With an 1 1/2, you're definately going to hear a clunk. I would say you found your problem. Hope this helps.
Dec 2, 2008 at 12:45 PM
