1996 Ford Ranger A/C cooling
173,000 MILES • 6 CYL • 2WD • AUTOMATIC
BRINMAN
My A/C will only cool with the selector is on A/C Max.
All other setting I only get hot air from the A/C.
Thanks
May 29, 2010 at 5:14 AM
  • 110,248 POSTS
The blend door is stuck. It determines if you get heat or AC. On max AC, you are recirculating the air in the vehicle. Thus, you bypass it. It is located near the heater core, part of the HVAC system.
May 29, 2010 at 2:18 PM
