HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Ford
Ranger
Engine
Computer
Location
SPONSORED LINKS
Computer location
ANNALDAPE
MEMBER
1994 FORD RANGER
6 CYL
2WD
MANUAL
52,365 MILES
Where is the computer located at (ecc) and how do you know if its going bad?
Friday, August 27th, 2010 AT 2:51 PM
MECHANIC
The Powertrain Control Module (PCM) is located at the LH rear corner of engine compartment.
How do you know if its going bad?
It depends on, what the problem is.
See diagram below for location
Image (Click to make bigger)
SPONSORED LINKS
Friday, August 27th, 2010 AT 5:40 PM
BRENDA HAMPTON
MEMBER
1 POST
1996 FORD RANGER
4 CYL
2WD
MANUAL
159,000 MILES
Where can I find the computer box on my ranger and how do I remove it.
Sunday, August 4th, 2019 AT 11:49 AM (Merged)
BMRFIXIT
MECHANIC
Right rear of engine compartment, through firewall
MECHANIC
Right rear of engine compartment, thru the firewall
Please
login
or
register
to post a reply.
Related Engine Computer Location Content
Iat Sensor 1991 Ford Ranger 2.3l
I Have To Know The Eec Pinout #'s For My Iat Sensor For My 1991 Ford Ranger 2.3l Cant Find Wires And Would Like To Rewire From Eec/ecu...
Asked by
homebuiltbikes
1 IMAGE
1991
FORD RANGER
Bad Ecm?
I Need An Engine Diagram Showing The Location Of The Engine Control Module.
Asked by
tbowman92
1 ANSWER
1 IMAGE
2001
FORD RANGER
1994 Ford Ranger Pcm
Removed Pcm, Reinstalled Jumed Fuel Pump And It Ran. Shut The Truck Off And Won't Start, Even If I Jump The Pump. Have Power To Injectors...
Asked by
blademan7
1994
FORD RANGER
1994 Ford Ranger Diagnostic
How Do You Jump The Diagnostic Connector To Retrieve Stored Codes Through The Malfunction Indicator Lamp
Asked by
jmounier
1 ANSWER
1994
FORD RANGER
Where Do You Connect A Code Reader?
Where Do You Connect A Code Reader? I Just Had A Full Tune Up On My Ranger A Few Weeks Ago. The Gas Gauge Isn't Working So I'm...
Asked by
onier
1992
FORD RANGER
VIEW MORE
SPONSORED LINKS
Overheating Symptoms
Engine Oil Change and Filter
Oil Change and Filter Replacement Chevrolet E
Online car repair manuals
