1995 Ford Ranger Slave cylinder bleeding
161,000 MILES • 4 CYL • 2WD • MANUAL
DSCHEFSKY
I just finished replacing my clutch assy & slave cylinder on my 95 ranger. I gravity bleed the system until the fluid was flowing freely. There isn't any clutch pedal and I'm confident of the bleed.
Is there somthing I've overlooked?
Thanks
Dec 3, 2009 at 3:09 AM
DOCFIXIT
  • 18,828 POSTS
Hi
Remove lind from slave operate clutch pedal hard? spongy? if hard reattach pump pedal 10 times wait 1 min. again then pump pedal with assistent hold pedal open bleeder close bleeder pump again until air out.
If spongy apply pressure to pedal use screwdriver to depress valve repeat till pedal hard then attach and bleed slave as above.
Hope this helps
Thanks for donate
Dec 3, 2009 at 3:41 AM
