random stalling
308,000 MILES • 4 CYL • 2WD • MANUAL
2GUYS
  • 10 POSTS
2.3 liter dies randomly for no reason. I was having trouble 6 months ago and thought it was fixed but it is acting up again. Replaced fuel pump, fuel pump relay, inertia switch, fuel filter, ignition switch, maf sensor, iat sensor, idle air bypass valve and PCM all recently. Don't know what else it would be but crank sensor. If so where is it and how do you change it. It sometimes will start and die. It wouldn't start for a week and now is running fine again. Irritating because you never know if it is fixed.
Apr 14, 2010 at 7:32 AM
KHLOW2008
  • 41,812 POSTS
Hi 2guys, Did you try to retrieve for trouble codes? Is the Check Engine Light showing?
https://images.2carpros.com/forum/automotive_pictures/192750_EngComp95RangerFig01_1.jpg
The crank sensor is located at right front of engine. Cam sensor is at top front of engine.
May 11, 2010 at 7:21 AM
2GUYS
  • 10 POSTS
Have had check engine light checked. The codes were bad iat sensor, bad maf sensor speed sensor fault and oxygen sensor fault. replaced iat and maf. I know speed sensor or oxygen will not cause the vehicle to not run at all for no reason or not start and then out of the blue run fine. So I guess it has to be coil pack or crank or cam sensor. That is all that's left isn't it?
May 12, 2010 at 8:23 AM
KHLOW2008
  • 41,812 POSTS
A bad MAF and IAT can cause non starting issues. Get those checked first.
May 12, 2010 at 9:53 AM
2GUYS
  • 10 POSTS
I have been cursed with this problem since last October. I have replaced the fuel pump, fuel filter, fuel pump relay, inertia switch, ignition switch, MAF sensor, IAT sensor, and crankshaft position sensor and was still having the same problem. I FINALLY figured it out. one of the wires in the wiring harness on the inertia switch wasn't locked in place anymore and had fallen about half-way down the connector but never came out. This is always why stalling was worse with a passenger, since it is in the passenger floorboard. I glued the wire where it couldn't come out and it is doing fine.
Jun 22, 2010 at 11:35 AM
KHLOW2008
  • 41,812 POSTS
Cheers, glad to know you have fixed the problem.
Thank you for the input.
Have a nice day
Jun 23, 2010 at 2:08 AM
JONNYRAINS
  • 6 POSTS
I had that issue as well I found my EGR valve was bad. Had a lot of carbon built up and would stick the plunger inside. Also clean out your throttle body connected to the air intake. Carbon and sludge builds up in there as well
Apr 10, 2014 at 9:55 PM
