Wednesday, April 14th, 2010 AT 2:32 PM
2.3 liter dies randomly for no reason. I was having trouble 6 months ago and thought it was fixed but it is acting up again. Replaced fuel pump, fuel pump relay, inertia switch, fuel filter, ignition switch, maf sensor, iat sensor, idle air bypass valve and PCM all recently. Don't know what else it would be but crank sensor. If so where is it and how do you change it. It sometimes will start and die. It wouldn't start for a week and now is running fine again. Irritating because you never know if it is fixed.
