1995 Ford Ranger help
180,000 MILES • 4 CYL • 2WD • MANUAL
LRC32
i have a 1995 ford ranger and the only things that work for electrical is headlights everything else inside the car does not work do u know what is wrong with the electrical or problems that could be going on
May 9, 2008 at 12:22 PM
MASTERTECHTIM
  • 4,750 POSTS
check connections at the battery and starter solenoid. also check the ignition switch inside the steering column, they are common for burning out.
May 9, 2008 at 1:20 PM
