1995 Ford Ranger FUEL FILTER REPLACE
140,000 MILES • 6 CYL • FWD • AUTOMATIC
WEZLEYZ69
JUST REPLACED MY FUEL FILTER AND SPARK PLUGS. TRUCK WILL NOT START. DID I MISS SOMETHING? TRUCK WAS ON EMPTY. COULD THIS BE PART OF THE PROBLEM? (SINCE REPLACING THE FUEL FILTER I ADDED 2 GALLONS)
Aug 28, 2010 at 4:25 AM
BLUELIGHTNIN6
  • 16,542 POSTS
need to cycle some fuel into system since you ran it out. to do this, turn the key on without cranking. listen for the fuel pump to buzz. it should run 2 or 3 seconds. when it turns off, turn key to off than turn back on again. do this several times to get the system primed back up and then crank engine to see if it starts.
Aug 28, 2010 at 4:34 AM
