Ford 1995 Ranger 89,000 miles with 3.0 engine. The gas hose from filler neck to the gas tank is leaking gas at fill up due to cracks or split in the hose just above the tank where the hose bends sharply downwards. A replacement hose is over $450.00 and labor cost is over $100.00. Can this hose be repaired with adhesive or some other gas hose rather than the Ford replacement hose? Do you know if there is an inner hose within outer hose? Part number for Ford hose is F47Z9034N.
Feb 13, 2007 at 4:37 AM
