1995 Ford Ranger drive shaft vibrates
176,000 MILES • 6 CYL • 2WD • AUTOMATIC
ROYB 1942
After replacing the carrier berring the drive shaft vibrates badly. It did not before the berring was replaced. What could be the cause?
Feb 10, 2009 at 10:33 AM
RANGERDANGER17
  • 224 POSTS
if you have a tach note the rpms when it vibrates then shift and and bring the rpm to the same point if the vibration happens at the same rpms its not the drive shaft
if vibration is not as bad in the next gear at the same rpms the drive shaft is bent or dented dirt build up or worn univeresal joints
if the vibration happens at the same rpm reguardless the gear its not the drive shaft
Feb 10, 2009 at 12:26 PM
