1995 Ford Ranger Bell rings intermitantly
200,000 MILES • 4 CYL • 2WD • MANUAL
JPRESTEL
When I get in the truck close the door and put on my seatbelt. I turn on the car and the bell for either the seat belts or the door continues to ring. Sometimes it goes off after awhile or never goes off.
Feb 9, 2008 at 11:10 AM
MERLIN965
it sounds like you have a problem with your door lock assy. Check to see if the interior light is on at the same time as the chiming is going on if so Ford has a revised door lock assy. that will correct that!!!!
Feb 27, 2008 at 5:57 AM
