Drive Train Axles Bearings problem
1995 Ford Ranger 6 cyl Four Wheel Drive Manual 120k miles
Shift motor won't respond to dash 3 position selector switch. Hot wired motor and it is operative. Don't know if switch on transfer case is okay. Used meter, and motor doesn't appear to be receiving signal from dash switch.
Fuse in Dbox is okay. Fuse in panel in cab is okay.
Next step? Replace motor? GEM? Dash switch? Any relays I'm missing? If so, where are they?
Oct 18, 2009 at 12:26 PM
