1995 Ford Ranger
98,000 MILES • 6 CYL • 4WD • MANUAL
POINTR6LITER
I have a 95 ford ranger 4.0 with stick. I have no clutch grab, its as if the clutch is stuck depressed but the clutch pedal is free and goes in an out just fine. As its turned on and running i can move the stick through all of the gears with no grinding and without using the clutch. Can you help me out.
Nov 17, 2009 at 5:43 AM
  • 110,248 POSTS
It sounds like the pressure plate is stuck. Have you taken anything apart?
Dec 2, 2009 at 2:13 AM
