1994 Ford Ranger Wiper motor
BREWCREW442
  • 1994 FORD RANGER
Electrical problem
1994 Ford Ranger 4 cyl Two Wheel Drive Manual
My wipers work at low speed when I turn the switch to high speed. They do not work at any other position, including the delay settings. The motor has been replaced and I was told there is no relay for he wiper motor on this truck. Is the switch bad or is it in the wiring?
Sunday, November 23rd, 2008 AT 4:21 AM
BMRFIXIT
  • 19,053 POSTS
Multi-function switch send position signal to the interval governor (located left side of the ashtray )
and then from it to the wiper motor
also check and make sure wiper motor has a good ground
need manual CHECK IT @
https://www.2carpros.com/kpages/auto_repair_manuals.htm
https://www.2carpros.com/forum/automotive_pictures/99387_Graphic1_80.jpg
Sunday, November 23rd, 2008 AT 6:12 AM
