1994 Ford Ranger water pump pulley not turning
141,300 MILES • 6 CYL • 2WD • AUTOMATIC
AMHUNT21
Hello - a couple days ago I had a squealing noise while driving my truck. Shortly after this noise started the serpentine belt broke. I thought that the belt had just worn out, so I replaced it. When I started the truck it immediately started squealing and I noticed that the water pump pulley was not turning. Would you say this is a water pump problem or something bigger?
Jan 22, 2009 at 1:46 AM
2CARPRO JACK
  • 11,533 POSTS
Sounds as though the water pump has locked up.Try removing the belt and see if the pump will turn by hand, if not a new one is in order
Jan 22, 2009 at 2:36 AM
