1994 Ford Ranger Tail Light Out on 94 Ford Ranger
1994 FORD RANGER
115,000 MILES • 6 CYL • 4WD • AUTOMATIC
ELFAIOLA
My low beams went out and it was a short at the headlight connectors (after I bought, installed, and returned the combination switch....which wasnt the headlight problem)
My tail lights are now not working. I just replaced the brake light switch located on the brake pedal. This did not change anything. I have checked all the fuses and checked the wiring at the brake lights (I thought it might be similar to the headlight problem)
Any suggestions? Do I need to replace the combination switch now? Any help would be greatly appreciated.
Thanks
Feb 8, 2009 at 3:18 PM
RANGERDANGER17
  • 224 POSTS
go back and check the fuses dont use a test light cause if fuses get wet the will blow and not work but they will test good with a test light so check and replace any fuses that look wet or burnt
double check to make sure you put the switch back in correctly
Feb 9, 2009 at 9:06 PM
