1994 Ford Ranger Starting Problems
173,000 MILES • 4 CYL • 2WD • AUTOMATIC
LAZYKITTEN18
Recently I have been having problems starting my truck. All the lights come on nice and bright when I turn the key but all I hear is a clicking noise. It has happened three times now. The only thing that seems to work right now is by jiggiling the wires going to the starter. Then it starts just fine. I was wondering if it is the starter relay. The starter sounds fine in itself when the truck is finally working properly.
Mar 3, 2008 at 1:53 PM
BIGCAT6460
  • 7 POSTS
Yes, there is a good chance that the starter relay has a problem. I have a 1994 Ford Ranger XLT that won't run without burning up my starter. Changed Starter, starter relay, battery, fuseable link, had alternator checked, it was fine, no loose grounds or anything, still it will not charge from the alternator. Still looking for answers to my problem too. I hope you get your problem fixed a lot faster than me, three weeks and counting. Good luck.
Aug 6, 2008 at 9:58 AM
