I've been having some starter problems with my truck. When I go to start it up all I will get is a click.
I have had the battery tested and it's fine.
I took the starter itself off and had it tested, it's also fine.
I've replaced the starter relay twice.
The last time this happened I took the starter off, had it tested, and when I put it back on and hooked everything up the truck started. It ran for about a month and now it's doing exactly the same thing.
Any ideas as to what it could be? Possibly a bad wire?
Apr 6, 2009 at 9:22 AM
