I had to replace the starter on my '94 Ford Ranger. Of course I had to many helping hands and wires got put on wrong or they forgot where they go. I have read the schematics and a chelton manuel and have figured out where the wires to the starter solenoid goes. The black wire is chasis ground, the large red wire goes to the nut opposite the braided wire that is going from the solenoid to the starter, and the smaller red wire is going to the L shaped tab on the solenoid. I got all of the wires hooked to the starter relay switch. Now my problem is that the wire from the relay switch to the started solenoid keeps getting extremely hot when I try to start the truck. What could be causing this problem? Could you please point me in the right direction?
May 25, 2010 at 12:25 PM
