1994 Ford Ranger spark
1994 FORD RANGER
PAUL H
Electrical problem
1994 Ford Ranger 6 cyl Two Wheel Drive Automatic ? miles
My ranger has no spark. I have made the useal checks ie; coil was bad replaced ignition control modual tested ok distributor cap wires etcnew. A head gasket replacement has just been completed , not by me, could something have been left unconected that would cause this. The motor turns over fine.
Aug 15, 2008 at 4:52 AM
BMRFIXIT
  • 19,053 POSTS
check fuses and relays
Recheck all wiring and connectors
check grounds
check crank sensor
check for power at the coil
check alarm system
Aug 15, 2008 at 11:33 PM
