1994 Ford Ranger Master Cylinder replacement needed?
147,000 MILES • 4 CYL • 2WD • MANUAL
VOICEGUY
After stopping at a gas station, I prepared to leave the lot when my brake pedal went to the floor. Pumping does no good. I still have fluid in the reservoir. I assume I need to replace the master cylinder? How do I go about doing that? Thanks! Boyce Lancaster
Dec 31, 2008 at 2:15 AM
DAVE H
  • 13,383 POSTS
MASTER CYLINDER
Removal & Installation
Disconnect brake warning light indicator wire from indicator switch. With engine off, depress brake pedal to bleed vacuum from brake booster.
Disconnect brake lines at master cylinder. Remove nuts retaining master cylinder to brake booster. Remove master cylinder. To install, reverse removal procedure. Bleed brake system. See BLEEDING BRAKE SYSTEM
Apr 14, 2021 at 3:40 AM
VOICEGUY
Hello Dave H.!
Thank you for your help...Happy New Year!
Boyce
DAVE H
  • 13,383 POSTS
no problem .. thats what we are here for !!
HAPPY NEW YEAR to you 2
Dave H
