1994 Ford Ranger Light on CHIME/bell
110,000 MILES • 6 CYL • 2WD • AUTOMATIC
PAUL BOWLING
The chime continues to go off when I turn my lights on in normal operation/driving as if I accidentaly left them on after killing the engine.The chime goes off when I turn the lights off.
where should I trouble shoot first to resolve this issue?
Could a scan test - clear codes/clear abs code or replacing spark plug wires have anything to do with initally causing the problem? It started imediately after those services were done.
Mar 2, 2010 at 1:39 AM
LEGITIMATE007
  • 5,121 POSTS
check the actual switch for the lights. for a short or loose connecttion
Mar 2, 2010 at 3:53 AM
PAUL BOWLING
Checking switches was a good idea. Light switch was functional. Localized the problem to the ingnition switch/ignition solinoid. I replaced that 3 years ago and rather than do so again and have to re- key the ignition, I chose to disconnect the bell that was easily accessible under the steering column & dash.
No other systems are directly affected as far as I can tell.
Mar 11, 2010 at 1:54 AM
LEGITIMATE007
  • 5,121 POSTS
very good, if you need anything else , dont hesitate
Mar 11, 2010 at 4:43 AM
