1994 Ford Ranger how to
LONGDUKDON666
  • 8 POSTS
1994 Ford Ranger 6 cyl Four Wheel Drive Manual
how do you change or retension a serpinetine belt?
Mar 13, 2010 at 9:11 PM
DAVE H
  • 13,383 POSTS
Inspect belt for fraying. If fraying has occurred, ensure belt and tensioner are aligned properly. If tensioner has reached its limit of travel, belt is excessively stretched and replacement of belt is required. If excessive noise is noticed from tensioner or idler, check for possible bearing failure. Belt tension adjustment is not required on vehicles with automatic belt tensioners. DO NOT apply belt dressing or any other additive to belt(s). Ensure belts are properly installed
https://images.2carpros.com/forum/automotive_pictures/266999_ra_1.jpg
Mar 13, 2010 at 11:57 PM
