1994 Ford Ranger gas tank
110,000 MILES • 6 CYL • 2WD • AUTOMATIC
IAMHUMDINGER
I didn't see gas tank anyway is it easier to raise back bed up and change fuel pump or is it easier to take tank off. can you tell me the specifics to doing it either way thank you
Jun 15, 2009 at 8:13 AM
BILLYMAC
  • 2,204 POSTS
hi.it is easier to remove the tank ,reason being you may remove bed but a croossmember may not let you remove pump.the tank comes out pretty easy the lines will be a pain but use plenty of wd 40 and they will come off. good luck billymac
Jun 15, 2009 at 10:34 AM
