1994 Ford Ranger gas smell
110,000 MILES • 4 CYL • 2WD • MANUAL
BROBERT
gas gage will not work, the coolen gage remain in the same position 1/3 mark, i smell gas around the truck , the oil gage works, why any i get this gas smell?
Feb 11, 2009 at 9:31 AM
RANGERDANGER17
  • 224 POSTS
the gas guage is in the tank it a float the sits on the fuel pump a new fuel pump assy is about 100 dollars
if the guage moves up after the engine warms up to the 1/3 mark the guage is good but if it stays at the same mark all the time is bad
if the gas smell is comin from the engine it is probably a leak on the lines some where if gas smell is comin from where the tank remove the bed and inspect the connection and vacuum lines
Feb 11, 2009 at 11:00 AM
