1994 Ford Ranger changing power steering pump
MINNIX2LEN
Steering problem
1994 Ford Ranger 6 cyl Two Wheel Drive Automatic
What do I need to do to change the powering pump on my '94 ranger?
Apr 27, 2009 at 5:32 AM
  • 110,248 POSTS
Remove the belt, the hoses to the pump, unbolt the old pump, drain it and remove it. Reverse order to replace. NOTE: the new pump will need bleed. Raise the front of the truck, fill the pump, with engine off, turn the wheels left and right. Keep adding fluid until it stays full.
Apr 28, 2009 at 1:44 PM
