1994 Ford Ranger brake fluid leak
1994 FORD RANGER
117,550 MILES • 6 CYL • 2WD • AUTOMATIC
ERIC-169
was driving my truck yesterday and i started noticing that there was something wrong because i had to start pressing harder against my brakes so i could stop then my abs light came on so i put my truck in parking and started checking my engine i saw my brake canister was empty so i checked for any leaks i saw none got under my truck and there it was my back right tire was covered in brake fluid can anyone tell what it might be and how much would i spend fixing it myself or should i take it to a garage? thanks a million guys!
Mar 28, 2009 at 5:32 AM
The wheel cylinder is leaking replace it then refill M/C then bleed the system.
Mar 28, 2009 at 8:48 AM
