1994 Ford Ranger Aftermarket fog light fix
ROBERT PALUMBO
Electrical problem
1994 Ford Ranger 6 cyl Two Wheel Drive Automatic 206K miles
94 Ranger Splash 4.0 Auto 206K I purchased this truck new and added the lower front 4 wheel drive valence/fog light kit for an awesome factory look. However, too often the glass lenses fall off the housing and break. There about $90 a light to replace. Is anyone aware of an aftermarket set alot cheaper that will bolt right in with only the wire connectors to modify?
Aug 6, 2008 at 1:27 PM
BLACKOP555
  • 10,386 POSTS
first try to put rubber isolating grommets on each side of the headlight to dampen it from the blows when it hits a bump. try jcwhitney.com, they have lots of high quality lights that arnt that expensive.
Aug 6, 2008 at 2:53 PM
