1994 Ford Ranger 4WD Operation
KBDENVER
Transmission problem
1994 Ford Ranger 6 cyl Four Wheel Drive Manual
This truck has the push button 4WD system, Warn manual hubs. I am having problems engaging the 4WD and want to check out the control module but I don't know where the module is, Autozone could not tell me and my manual dissapered...help!
Oct 9, 2010 at 8:53 AM
  • 110,248 POSTS
The actuator is located on the transfer case.
Oct 9, 2010 at 4:53 PM
KBDENVER
I know where the shift motor is. There is an electronic control module somewhere in the cab I am trying to find. In a post on this site I found instructions on how to test it but not the location of the module. Thanks for your assistance.
Oct 10, 2010 at 5:45 AM
  • 110,248 POSTS
The 4x4 module is located behind the driver’s seat. Also, check the #7 fuse in the vehicle and fuses under the hood.
Oct 10, 2010 at 4:29 PM
MILLERTIME2316
It is behind the driver side back seat if single cab then behind passenger seat.
Apr 13, 2019 at 4:21 AM
  • 110,248 POSTS
Welcome back:
It indicates it to be behind the driver's side.
Apr 15, 2019 at 1:11 PM
