i have a 94 ranger that wont start doesnt turn over at all. just clicks. i replaced the solenoid still have the same problem.
Aug 17, 2009 at 8:54 AM
WINEBURGER
MEMBER
you either dont have enough power to your starter or a good ground or most likely a bad starter
Aug 17, 2009 at 8:59 AM
CHARLIE J
MEMBER
it worked when i jumped it . but it acts like it doesnt have enough power by itself
Aug 17, 2009 at 10:50 AM
WINEBURGER
MEMBER
check to see if your battery is fully charged 12.6 volts if not charge the battery check connections
Aug 17, 2009 at 11:07 AM
CHARLIE J
MEMBER
its got 13.4. and i got new terminals too
Aug 17, 2009 at 11:09 AM
WINEBURGER
MEMBER
you have a voltage drop across one of your connections. take a set of jummper cables use negitive to starter motor if no change use positive to relay battery side then the other then starter or use a meter and look for voltage drops across each connection should be no more than .2 volts drop .or if it will start take it to autozone they will check it for free
