1994 Ford Ranger 1994 ranger 8 plug wires won't run
1994 FORD RANGER
198,000 MILES • 4 CYL • 2WD • MANUAL
SPINNER04
1994 8 plugs 4cyl won't run missing, back fire through the breather,kicks back, changed coil packs, wires, sparks plugs and wires, checked timing, check for leaks at the intake, and vacuume hoses, changed module, checked fuel pressure, runs good when the engine is heated up
Jun 15, 2010 at 10:15 AM
  • 110,244 POSTS
Has the check engine light come on when this happens? Have you checked the crank sensor and the temp sensor?
Jun 16, 2010 at 2:05 PM
