1994 Ford Ranger
ADIDASB23
1994 Ford Ranger 4 cyl Two Wheel Drive Automatic
my dash lights went out ,my abs light started flashing ,& my brake lights stopped working all at the same time i thnk it is all related but i dont know what to do
Nov 19, 2009 at 8:54 AM
RUSTYBUCKET
Sounds like you have an electrical short. The best place to start is at the fuse box. make sure they are the right amperage and in correctly. follow the lights so to speak. once one is fixed the others will reveal themselves. The dash could be a simple bulb. the abs could be flashing to give you a code to the problem see if it flashes the same number of times or all the time.
hope it helps.
Nov 24, 2009 at 11:43 AM
