1994 Ford Ranger
KATHY0000
  • 1994 FORD RANGER
Shakes or Wobbles problem
1994 Ford Ranger 4 cyl Two Wheel Drive Manual
my truck just started to miss really bad and has no power, I have changed out the plugs and checked on loose hoses. What else can I look for?
Tuesday, August 5th, 2008 AT 9:04 PM
OBXAUTOMEDIC
  • 3,711 POSTS
Is the engine light on? If so have codes pulled if possible.
Here is something to try. Start the vehicle and one at a time pull each plug wire off. If vehicle stalls out or runs even worse then most likely the coil pack. If no change then possible that the injectors or the injector harness is the cause.
Post findings here in forum
Tuesday, August 5th, 2008 AT 9:29 PM
