1993 Ford Ranger water not going thru heater hoses
200 MILES • 4 CYL • 2WD • MANUAL
WANEYBUG
No heat, removed heater hoses from heater core, and water does not pump thru either hose. Radiator and thermostat has been changed. Was told the water pump needed to be changed.
Don't know what else to do.
Dec 6, 2008 at 9:54 AM
BLACKOP555
  • 10,386 POSTS
if coolant isnt moving through any hose, chances are the water pump is no more good.
do you have a heater control valve?
Dec 28, 2008 at 4:10 AM
