1993 Ford Ranger Vibration Above 65 MPH
GMATT0824
1993 Ford Ranger, 4 cylinder, 147,000 miles. I recently changed my shock absorbers on my truck. Shortly after that I developed a violent shake at above 65 mph. Had a complete front end inspection by 2 different mechanics. Found drivers side wheel had left-right play movement. Replacement of the center link fixed that problem. I've had 2 alignments performed by both mechanics, had the wheel bearings re-packed, and all tires rebalanced and rotated. Both mechanics found that ball joints and tie-rod ends are good and in working order. Even after 2 alignments, I still have a slight pull to the right and there is some play in the steering along with the vibration at high speed. Vibration starts at same speed whether in 4th or 5th gear, so I don't think it's a motor mount problem. The only thing I can think it might be is the Steering Gear Box, but I can't afford $400+ repair only to find out that isn't the problem. Could the shocks also cause a problem like this? They do seem pretty stiff after 2 months of use. Shocks are "Grabriel Ultra". Thanks for your time.
Matt
Apr 7, 2006 at 7:32 AM
LOVESCARS
  • 359 POSTS
Check the brake calipers. ford trucks especially rangers vibrate and finding the cource can be an expensive adventure.
Could be the rear differential or the driveshaft center bearing if so equipped could be a tire??
Apr 8, 2006 at 1:25 AM
RONSON
  • 77 POSTS
Had same trouble with 91 Ranger.Replaced front end parts and still had vibration.Found problem to be rear universal joint. Replaced myself for ten bucks.
Feb 20, 2010 at 3:12 AM
Suggested Repair
Check the brake calipers, tires, rear differential, and driveshaft center bearing if equipped. A similar Ranger vibration was traced to a worn rear universal joint, which is worth inspecting and replacing if loose.
Conversation Summary
A 1993 Ford Ranger developed a violent vibration above 65 mph shortly after the shock absorbers were replaced. Front-end inspections, center-link replacement, alignments, wheel-bearing service, and tire balancing did not fully resolve the vibration, slight right pull, or steering play. Suggested checks include the brake calipers, rear differential, driveshaft center bearing, and tires; a similar Ranger problem was caused by a worn rear universal joint.
