1993 Ford Ranger starter
DOUG DAHL
  • 1993 FORD RANGER
Engine Mechanical problem
1993 Ford Ranger 6 cyl Four Wheel Drive Manual
starter stopped working and would only make clicking sound. Put new starter in and it still only clicks. Check old starter by using the bench method it seemed to work fine. What maybe the cause? Jumped the clutch switch and it didn't make any difference.
Sunday, September 26th, 2010 AT 5:23 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Could be bad ignition switch, what happens when you jumper starter solenoid while on vehicle?
Sunday, September 26th, 2010 AT 5:31 PM
DOUG DAHL
I have tried that it makes no difference still justs clicks.
Sunday, September 26th, 2010 AT 7:01 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Test starter relay, its on the fender panel near battery.
Sunday, September 26th, 2010 AT 7:08 PM
