1993 Ford Ranger Replacing the distibutor
DUMBO
Engine Performance problem
1993 Ford Ranger 6 cyl Two Wheel Drive Manual
My sons truck had striped some gears on the distributor...after buying a replacement distributor and placeing it in...or course the timeing was off....after removing and replaceing it several times was able to get it running enoough to get it home....is there a way to time the motor without having to pull and rebuilt the whole thing.....please advise.
Feb 23, 2010 at 6:32 AM
  • 75,988 POSTS
Put the engine no.1 piston on its compression stroke/TDC then line the crankshaft pulley timing marks/scale to zero degree-install the distributor making sure the rotor is pointing to the no.1 cap tower then follow the firing order rotation-then adjust the ignition timing
Feb 23, 2010 at 6:44 AM
DUMBO
Thanks for your help......was able to find the marks and reset the distributor....runs great now....again, thanks for your help
Feb 23, 2010 at 8:54 AM
