1993 Ford Ranger Pinging
1993 FORD RANGER
15,000 MILES • 4 CYL • 2WD • MANUAL
DAVID PARKER
My truck is a four cylinder with eight plugs. I have change the plugs. When I run regular gas my truck pings really bad. If I run high test gas it runs fine. What is the problem?
Jan 14, 2008 at 6:37 PM
VIDEOTP
Dave:
You may already know this but it totally seems like your timing is too far advanced. Loosen the Distributor clamp bolt and turn your distrubutor just a very small amount counterclock wise. then tighten the clamp again. Or get a timing light and set up to the engine specs.
Jan 14, 2008 at 6:54 PM
