1993 Ford Ranger Lights & ABS light
TJD1
Electrical problem
1993 Ford Ranger Two Wheel Drive Automatic
When I try to switch my running lights on, they fail to come on, and my ABS light starts flashing. My headlights will come on if I pull the switch all the way out, but still no running lights, and the ABS is already flashing. The flash count is 16, which I understand to mean all is well ?
I`ve changed the light switch. All my bulbs are good.
If I play with the swith a bit and hang it between running light and headlight, both will come on, but my ammeter will do a sporadic little jig from time to time.
What have I got wrong here ?
Sep 4, 2010 at 7:59 AM
BILLYMAC
  • 2,204 POSTS
check the harness going to the brake lights for open or shorted ground
Sep 12, 2010 at 2:35 PM
