1993 Ford Ranger Leaking
1993 FORD RANGER
15,000 MILES • 4 CYL • 2WD • MANUAL
COWBOYZ_FROM_HELL2002
My 1993 Ranger has a strange anti freeze leak. It leaks on occasion , not all the time on the drivers side of engine. From underneath I can see it coming off the oil pan , but from above I can't see much of the motor/block. The intake & fuel injection system covers most of that side of the motor. Is there any possible hidden hoses down there somewhere or is it most likely the head gasket leaking? As I said it doesn't happen all the time , I can pull up somewhere & within a few minutes there may be a puddle of anti freeze almost a foot in diamater , drive it 10 or 15 minutes park it & not leak a single drop. Any help would be appreciated thanks.
Apr 20, 2008 at 10:06 AM
TMCTECHPOINT08
I have the exact same problem. Hope someone can help
May 8, 2008 at 9:36 AM
FORDGUY4U
  • 8 POSTS
In most case its a rotted out timing cover. This is a very common concern on the older Explorers.
May 8, 2008 at 12:19 PM
