1993 Ford Ranger Fuel leak after injector replacement
108,000 MILES • 6 CYL • 2WD • AUTOMATIC
ANGELEA56
I have recently purchased a 93 Ford ranger
I have replaced the # 5 and 6 fuel injectors but am experiencing a fuel leak. What could be causing this as i have taken off the lower manifold twice to see if I have tightened them properly but i still have a fuel leak. I am an apprentice mechanic and have not run into this issue before hope you can help
Aug 21, 2010 at 6:03 AM
DOCFIXIT
  • 18,828 POSTS
Hi
Where new O rings installed with light lubing of oil?Clips on tight?
Let me know
Thanks for donate
Aug 21, 2010 at 6:15 AM
ANGELEA56
I put new o rings on and used vaseline not oil and tightened the clips
Aug 21, 2010 at 6:51 AM
DOCFIXIT
  • 18,828 POSTS
Clean off Vasoline coat with light oil
Aug 21, 2010 at 8:28 AM
