1993 Ford Ranger engine died going down interstate
169,000 MILES • 4 CYL • 2WD • MANUAL
CASPANER
engine died going down interstae oil pressure went to 0 the motor turns over but will not start any ideas about where to start or maybe what the problem is
May 5, 2008 at 10:19 AM
MASTERTECHTIM
  • 4,750 POSTS
the oil pressure went to 0 for how long before the engine died on you? have you tried spraying starter fluid into intake to see if that will make it run? also remove a spark plug wire and have someone crank over engine and see if it sparks (make sure its close to metal on engine)
May 5, 2008 at 12:34 PM
