1993 Ford Ranger engine
FIREHAWK1951
Engine Mechanical problem
1993 Ford Ranger 6 cyl Two Wheel Drive Manual 300k + miles
what is mounted below the oil filter on a '93 ranger by the starter motor i need to know because the bolt worked it's way loose and i need to know the size it takes
Feb 22, 2009 at 9:09 AM
RANGERDANGER17
  • 224 POSTS
well give me some more information
wat side is the oil filter on (facing the engine passenger or driver)?
what side is the starter on ?
is it run by the pully ?
does it have any lines runnin to it hydrualic or vacuum?
is it on the exuast pipes?
Feb 24, 2009 at 8:20 AM
