1993 Ford Ranger EGR valve question
89,000 MILES • 4 CYL • 2WD • MANUAL
FISHINDINO
  • 5 POSTS
The number 3 cylinder is not functioning. It is a California emissions vehicle. Would a faulty EGR valve cause this? It would work some then quit, now it will not work at all.
Mar 12, 2009 at 11:49 PM
  • 75,988 POSTS
What do you meant by this-is it firing or what ??? I don't think the EGR valve will cause a cylinder not to function properly
Mar 12, 2009 at 11:55 PM
FISHINDINO
  • 5 POSTS
It is not firing.
Mar 13, 2009 at 12:34 AM
  • 75,988 POSTS
If there's no spark-check the plugwire or swap for a working one and see what happens
Mar 13, 2009 at 12:41 AM
FISHINDINO
  • 5 POSTS
I already changed plugs and wires. I also replaced both coil packs, no change.
Mar 13, 2009 at 1:55 AM
  • 75,988 POSTS
Check and test the crankshaft positioning sensor in right front of engine bay.
https://images.2carpros.com/forum/automotive_pictures/12900_cps1_8.jpg
Mar 13, 2009 at 2:19 AM
FISHINDINO
  • 5 POSTS
I will check it out, and let you know. Thanks
Mar 13, 2009 at 2:51 AM
FISHINDINO
  • 5 POSTS
I was misinformed, it is firing, just no compression on the number 3 cylinder.
Mar 13, 2009 at 3:21 AM
  • 75,988 POSTS
No compression on no.3 could be valves/rings/cyl wear
Mar 13, 2009 at 10:35 AM
