Crank shaft position sensor
DARREN'S WIFE
Four cylinder two wheel drive manual.
Where is the position sensor located?
Aug 19, 2008 at 2:43 AM
BMRFIXIT
  • 19,053 POSTS
in right front of engine.
Aug 19, 2008 at 10:31 AM
DARREN'S WIFE
Is it behind the pulley? what do I need to take off in order to get to it?
Aug 20, 2008 at 7:12 AM
BMRFIXIT
  • 19,053 POSTS
Removal (2.3L):
1.Disconnect negative battery cable. Remove accessory belt(s). Remove crankshaft pulley, hub, and belt guide. Remove timing belt outer cover retaining bolts. Release cover tabs.
2.Remove timing belt cover. Unplug crankshaft sensor wire connector from engine harness. Remove crankshaft sensor four wire connector by prying out on red retaining clip.
Caution: Always turn engine in direction of normal rotation (clockwise as viewed from front of engine).
3.Rotate crankshaft to position crankshaft key-way at ten o'clock position to place vane window of inner and outer vane cups over crankshaft timing sensor. Remove crankshaft sensor retaining bolts and plastic wire harness retainer. Remove crankshaft sensor.
good luck
Aug 20, 2008 at 9:34 AM
MICHAEL 1313
I have a 1993 Ford Ranger 3.0. the pick up coil went out. How do I replace it?
Oct 1, 2016 at 4:42 AM
