1993 Ford Ranger Clutch
170,000 MILES • 6 CYL • 4WD • MANUAL
JDEVLIN
I just recently replaced the clutch in my 1993 Ford Ranger, which included Clutch Disk, Preasure Plate,Throwout bearing, Slave Cylinder and Master Cylinder. I try bleeding the system but I can't seem get the clutch pedal to build up preasure. Any thoughts
Jan 26, 2008 at 2:12 PM
MIKE H R
  • 3,094 POSTS
At first there would be little pressure. pump the clutch up even if it goes to the floor, then hold it down while someone loosens the bleeder screw to let the air out , eventually the fluid will replace the air but you will have to keep bleeding it until the fluid replaces the air in the system and the cluch pressure builds up.
Jan 27, 2008 at 2:49 AM
