1993 Ford Ranger 3.0L 4x4 auto 134,000 miles
FORDFORLIFE
My 1993 3.0L auto 4x4 ranger cuts out and backfires when you put the gas pedel on the floor. If you don't let up truck will cut off. I have checked fuel pressure, changed fuel filter, spark plugs, wires, and air filter. I have cleaned the MAP sensor and took off the cats. Still having the same problem. Truck runs fine until full throttle. I'm thinking maybe the throttle position sensor.
Jun 17, 2007 at 9:12 AM
FORDFORLIFE
I tried to check the old tps and it seems to be working right. Is there a Wide Open Throttle sensor on a 1993 3.0L? If so where and how do you check it?
Jun 18, 2007 at 10:23 AM
FORDFORLIFE
I changed the tps and still cutting out and cutting off if you dont let off the throttle on the floor.
Jun 21, 2007 at 12:17 PM
