1993 Ford Ranger
JJBACKMAN
Brakes problem
1993 Ford Ranger 6 cyl Four Wheel Drive Manual
I have replaced all new rear brakes in my truck and the one side seems to lock up and drag going forward .when i spin the wheel while on the jack there is no resistence rolling backwards,but then there is when i spin it forward?do i have the shoes backwards or something?
Nov 23, 2009 at 11:59 AM
OBXAUTOMEDIC
  • 3,711 POSTS
It is a possibility. I would suggest you take the other side off and look at it and compare the problem side.
Take a look at each part especially the steel bar at the top that goes between the shoes. Also check the e-brake components.
Dec 2, 2017 at 6:53 AM
OBXAUTOMEDIC
  • 3,711 POSTS
Here's a diagram...
https://images.2carpros.com/forum/automotive_pictures/188069_93rangershoes_1.jpg
