1993 Ford Ranger
125,890 MILES • 4 CYL • 4WD • AUTOMATIC
FASTFREDDY
I here a noise coming from the back end of the pickup, It sounds like it is coming from the rearend. I only makes a noise when you are going in and out of drive ways. I lifted the rear end of the ground and you can here the clunking sound a little bit, is this normal except for the sound.
Oct 6, 2009 at 12:24 PM
  • 110,248 POSTS
Did you check the u-joints? Is the differential fluid full?
Oct 28, 2009 at 1:19 AM
