1993 Ford Ranger
SOLDIERBOY2316
Tires and Wheels problem
1993 Ford Ranger Two Wheel Drive Manual
my pas wheel beerings needed changin bad. the outer beerings got so hot and beaten that it broke apart. the same is with the inner beerings i got the inner beerings and new seal in but the part of the beerings that the beerings rotate on and around is stuck on and i have tried degreaser and i put vise-grips on it and tried to beat the thing off but its stuck britty bad. i know its part of the old and destroyed beerings because it looks just like the bottom part of the new beerings but alot worse. how can i get it off so i wont have to spend money to replace the whole thing?
Jan 8, 2010 at 7:55 PM
  • 110,251 POSTS
The only thing I can suggest is heat it. Heat causes metal to expand. Hopefully you'll be able to get if off. Keep in mind, the spindal may be damaged. If you can't get it off, you will need to replace the entire part.
Jan 12, 2010 at 1:39 AM
